Is the Metco wagon LCA different than the sedan LCA by just the sway bar mounting? The pictures look visibly different in where the sway bar mounts fore/aft, but both look like they mount to the bottom of the LCA. If the wagon is 2" wider than the sedan (both frame and LCA mounting points on the axle) - how does the sedan RSB mount to the wagon LCA's here?
Sedan
Wagon
I was under the (possibly incorrect) assumption that I could use any "Impala SS" upper/lower rear control arms on a wagon. The lowers might be spaced wider, but the control arms themselves were the same. Can anyone confirm?
Sorry if this is getting a bit off topic for the crown vic RSB thread...
