Which application were the end-links for?Worked great for me.. thanks OP!
I think I used the moog ones the OP gave part numbers forWhich application were the end-links for?
If you remember the part number, that would be even better.I think I used the moog ones the OP gave part numbers for
Just read this thread from the start. OP gives all that info.If you remember the part number, that would be even better.
I believe I used brackets for a larger size swaybar and just cut a bit off of where the bushing is slit to make it fit the smaller swaybar.What Energy Suspension bushings is everyone using for the 17mm bar? I got 9.5121G but the bolt holes on the included brackets aren't wide enough to attach to 3" exhaust clamps. Greasable bushings would be nice, too...
It seems Energy Suspension has 2 main styles of bushings. The "small" ones (0.625" bracket to swaybar centerline) and the "big" ones (0.750" bracket to swaybar centerline). The ones I ordered are the "small" ones, and those brackets aren't wide enough. But I can't find any "big" ones for 17mm swaybar, and I can't find brackets for "small" ones that are wider.
