Before I 'discovered' the Crown Vic to wagon rear swaybar swap.
The full sized Bronco/F-150 ('80-'96) rear sway bar assembly will actually bolt right in some applications, and,,,,, is a 'almost' direct bolt in, on other applications! The length of the mounting link bolts will have to be shortened.
Back in the late '80's I built a '48 DeSoto Rod, with a '55 DeS Hemi. A pack of Camels could barely fit inder the front bumper. Did that Bronco bar swap. (Shortened up the link bolts ay 6" or so) It was a night, day, differnce in handling!
What baffles me is, how are you guys able to go to the Ford DEALER and buy a brand new Merc/CV bar, for under a hundred?! They want 2-3 hundred for just the bar, around here!
Also, I noticed most of you guys are using a 3" or whatever, muffler clamps, as the rear end housing to bar mounts. (If it works, GOOD!)
But, I torched the bar to rear end housing mounts off the CV, and welded them on the Wagon housing in the same location as the CV.
These mounts I torched off the CV, looked like the leaf spring pads that the leaf spring center bolt goes into. Of course the CV pad didn't have that center aligment hole, it had a slot and a threaded hole for the mounting bolt to thread into. (there are pictures I took, somewhere in the archives. I'm afraid to go in there and look for them. I heard that a member on here, went in the archives to look for something and hasn't been heard from since! Weird organ music payin' in the background)
I also noticed you guys are using Y2-K and above, bars. There was a rear end change of some sort in the CV's in the late '90's (not sure, or care, what was chaged) But, I am courious now as to how the Y2-K and up rear bars are mounted to the CV/Merc rear end housing? Mine was off a '93 CV cop car.
I notice you guys are using that 'slot' in the frame gusset. I welded a piece of filler metal in that slot to make a round hole for the busings to fit, just like the CV. That gusset is just as strong as the frame, and will support the swaybar link bolts/bushings. Providing that gusset is badly rusted. Just like on the CV's/Merc's, if it's badly rusted, the bushing will pull through, that's all.
If the wagon frsme is rusted too bad, then either, the rear bar will have to be fastened to the LCA's or weld a better gusset plate,,,,,,.
Glad you guys are enjoying the 'imporved' handling, at a frugal $$ layout, without LCA failures.
