So I have a 96 9c1 with wire harness issues. I found a 96 roadmaster wagon lt1 with a clean harness but im not sure if itll work it looks the same tho. Can I use it?
They are identical.
Let's start with , which harness?
Body? Engine ?
Body harness which will include wiring on the left fender , not even close
If engine , does the Buick have a mech fan ?
If it does the fan wiring will be different
It will also be missing at least 1 SEO power wire ( not an issue unless you are using police wired stuff)
The Buick will also have the speed sensitive steering wiring , likely not an issue.
So likely useable and adaptable
BUT the harnesses are not identical
I assumed engine, and that he would be wise enough to pick one with the same fan configuration.
