·On the BFG drag radial what is the way to get them ready for the run, just spin them a little or try to get then hot? how much air should I run in them? Thanks
Are you saying that you had 275/40/17 BFG's?? If so, I'm running those at 17 PSI. Could be that 22 PSI was a bit tight...???Originally posted by LeadSSled:
....launching on "warmed" BFG DRs was no problem. After the 2800 Vigilante was installed, I had to heat the crap out of them - a 12-15 second burnout....These were the 275/40R17 version.
