thank you for the join. I have a question if could you help me out. I have a leak coming from the driver side block I think. it was leaking on the block or the exhaust pipes and it started smoking. I would assume that what was causing the smoke. I could see a lot of water on the fire wall and on the plug but could see the water leak. I could take a picture and videos of the area. I can't upload the video but hope this picture helps. thank you in advance if you can help me out? this is on my 99ss
If it is truly the head bolt and that is not spatter,
up around a head bolt is a bit of a rarity but I have seen it .
Problem- question is , is, has the thread sealer failed or is the coolant coming across the deck ?
In my mind, the only correct solution is pull the heads .
Stop gap would be GM " pellets"
Semi stop gap would be remove the head bolts one by one in order, clean , seal, torque one by one.
If it was mine and it is coming up the head bolt, I would pull the heads.
Is that a washer under the head of the bolt? Can't remember if the stock head bolts came with washer. Don't think so but remember. If so, looks like that was a possible quick fix maybe?
Thank you
here is some more pictures thank you
