Did GM change the design of the waterneck gasket at some point? My FSM shows it to be a flat gasket that covers the are extending around the 2 bolts. Alldata shows the same. Autozone only carries an O-ring for the water neck, and thats what my local stealership has listed. Is the O-ring sufficient? I bought a delco thermostat to install when I replace my pump and it didn't come with anything as far as seals go.
Is that a separate gasket, or is that the one thats attached to the thermostat I bought? I never did an LT1 thermostat before, only 305s and 350s.
The thermostat should come with the rubber O ring necessary for sealing the goose neck. If someone put any other gasket material on there before, it will have to be completely removed.
yeah, there is one gasket for the thermostat (round o-ring) and one for the housing as you described, which extend around the 2 bolts. i didnt use any sealer/RTV but some locktite on the bolts, and brand new stainless bolts.
I thought there was a gasket there, but my GM dealer didnt have anything listed for there. The only thing I found was advance auto has some performance one for almost $20 (just for a gasket).
· Banned
No gasket, its just a o ring around the tstat.
