1 - 11 of 11 Posts
Well the Fleet is in tha garage for the winter
got some plans 2 go the whole car through for weakspots
like Engine parts . Electronic parts.
Hidden rust spots and so on
what have you notice as weak part on your Fleet
:eek:
The Climate control!!
Are you going for performance stuff? If so, the Valve springs get weak after 50k. mine were bad at 150k. they would start to float at about 4000 rpms. Other than that, mine was pretty strong until it hit a tree. Also, the headlight harness is said to be very weak, and my fuel pump wires inside the tank were melted. Didn't find this out till last week when I opened the old gastank to use the pump.
I don't 100% understand what your asking.
Sorry, mines a 94 with the LT1, so I donno what applies to an LO5.
F
Having friends work on it instead of professionals
An applaudable undertaking. Your car will love any attention you show it. Alot depends on your budget, but you could replace absolutely EVERY 14 year old hose, rubber fitting and valve/solenoid under the hood and it would not be money wasted.
Lots of pet-peeves in common w/ B- bods as listed above (plus dozens more), but it would truly take a nutcase to do something as wak and D- specific as rebuilding the Autolevel air compressor or somesuch.
i understand that you dont understand me 100% :D see im from Denmark so im not 100% well formulated in english
and due 2 the fact im the only 1 in the whole country that got
a 91-96 Fleet there aint much help 2 get around here
What i mean bye weakspots is with my old caprice there was the moldings
as you know there not that easy 2 maintain or get new once
the wagon allso has problems with water in the spearwheel
box and the rubber that goes around the window get squeezed
up in the window frame .....and so on
That is what i mean by weakspots :eek:
stuff like springs get weak after 50k and stuff like that
Thank you all
F
i understand that you don't understand me 100% :D see im from Denmark
Hey! Me too! Well, my great grandfather was from Rue, Denmark.
From the sparsity of replies you can see not as much notable as might have otherwise been the case for a stamped-out hi-production rate 10+ year old GM vehicle. As I alluded to above, the Autoleveler has a habit of going 'wonky' (um, a Fleetwood-specific term -- you don't want to know).
Other than that, the rattles and squeaks from old age are the most unnerving things I've noticed, and that's only because the car started out tighter than most other old GM boats I've been used to. I went ahead and bought all new rocker trim mounting clips when I repainted everything. Costly sure, but alot were cracked and broken anyway and I thought it cheap insurance against replacing falling-off $350 replacement trim pieces. Yikes
Suspension carries alot of weight around, and long wheelbase provides ample opportuniuties for curb rash episodes. So, I'd have to say that since our cars aren't really rustbuckets to begin with, it's the suspension and regular mechanical PM (Periodic/Preventive/Programmed Maintenance) I refer to above that keeps 'em tiptop.
Alot of guys probably wished they'd just replaced the waterpump at about 130,XXX miles (your kilometers may vary ;) ) BEFORE it started dribbling from the weephole instead of having to add replacing their previously-perfectly-functioning-but-now-drenched-dead-OPTI too as part of the WP repair procedure. :mad:
You could buy both rear ABS/TC sensors just for grins - and while they're ONLY $5X-6X from Dal. They're sensitive dam things, and seem to get alot of exposure to roadkill and other shrapnel.
If you plan to keep it 2-3 more years and the frontend is still pretty much original, then just replace everything from idler arm & centerlink, to tie-rods, to swaybar bushings -- and everything in between. You can amortize your elevated quality of life easily over the period of just a couple years to make all that a sound investment.
That's all I got. Boys? Any other ways to help Denmark here spend his Euros?
Thanks Allot 96Balck stuff like that i need
I fixed some stuff when bought it back 2003 just cosmetic stuff
repainted it, new moldings, headlights,switch bumper,as i even bought a second fleetwood from chicago and switch parts and sold it again
it got 136000 miles on the meter now and thought whats next 2
look at like engine , waterpump and so on
it's also hard to get junkyard parts because most us yards dont ship overseas
if any of you know a junkyard that ships overseas
let me know
i photoshoped it a little more glossy
Mighty pretty car. You don't mind spending loot on keeping up her looks, do you?
Do you have ORANGE bulbs in your reverse lamps?
:confused:
And how in the hayol do you get away without fender signals over there?
Year i spend allot of time on my car ( before i got kids :D )
i think im almost there just want 2 bee on top of things
and year it is orange turn signals in the back :eek:
over here you got to have that . and this is the selution i came up with
i can see Dan got the once i need for the back were did you get them my fellow Dane :D
Regarding the fender signal i did a little trick
i had some small gm fender signal and drilld and hole in the once
up in the frontli ght and glued it on . then it got the same viewing point as if was between the front wheel and the front door
1 - 11 of 11 Posts
