finially after two freakin weeks my extended trailing arms are in. They even sent me the wrong ones, i ordered the fixed legnth ones and they sent me the asjustables, and from what i remember they were about 200 more. I going out to install them rite now and ill probly have plenty of questions so ill let yall know how it goes
With the extended you need the adjustable I thought...
Have fun, the install isn't hard, I just did this a couple weeks ago.
well the adjustable is just for pinion angle ajdustments but i just wanted the fixed legnth ones. and my install isnt going so good, since the uppers were broke off the rear i cant get the bushings out
If they're hard to get out you may have to drill the rubber out then knock the metal sleeve out by folding it in on itself with hammer and chisel.
Yea, I had to use a sawzaw to cut wedges in the original bushings then I was able to take them out. Pain in the butt. I tried all sorts of "normal" things like wasting $90 on a bushing removal tool (stripped the threads right off the first try and that was by hand). With the sawzaw, they were out in 2 minutes flat.
alrite i worked on the thing all nite and finally just got done a little while ago, the rubber parts of the bushings just fell out but the metal part were so mangled i had to user the sawzall. check out what one of the uppers looked like
