"Father Knows Best"
Also be sure to check if the drall elbow is still there, as they are known to fall off. If the elbow is missing you can probably find one at a local parts yard. And while you are in there pick up a couple feet of the clear flexible hose so you can redirect the output of the elbow away from the frame. - Peter
