The tiewraps are not under any stress, and will not rust, so they are cheap and effective. They are only there to keep the spring from bouncing out of the seat.
I've never heard/read about this in the past so let me ask a little bit here...The tiewraps are not under any stress, and will not rust, so they are cheap and effective. They are only there to keep the spring from bouncing out of the seat.
The rear drop springs are so short, that they could fall out if the conditions are right. When you jack the rear to change a tire, the suspension must drop far enough to get the tire out from under the skirting. This requires a stock shock. To do so allows the axle to drop far enough that the spring no longer touches the upper spring seat. At that point, the spring can fall over, and not engage the perch. Strapping it to the lower perch alone could remedy this, but for a positive approach, trapping the spring is much preferred. I have had the springs fall out of alignment, and ended up against the frame completely behind the spring seat. It is not a stretch to have the spring completely fall from between the axle and frame, as there is no lateral support for the spring.I've never heard/read about this in the past so let me ask a little bit here...
Are you saying that when the suspension system in in jounce, that you have had a rear spring come out of it's "home" resting area?
I would think that in a normal state of compression that they're not going to go anywhere, and then on the suspension at it's peak travel in jounce, that the spring would still be held in there rather well because of the shock limiting that travel, and the spring still being under some compression.
So what's the scoop here Fred?
Thanx!
Fred,The rear drop springs are so short, that they could fall out if the conditions are right. When you jack the rear to change a tire, the suspension must drop far enough to get the tire out from under the skirting. This requires a stock shock. To do so allows the axle to drop far enough that the spring no longer touches the upper spring seat. At that point, the spring can fall over, and not engage the perch. Strapping it to the lower perch alone could remedy this, but for a positive approach, trapping the spring is much preferred. I have had the springs fall out of alignment, and ended up against the frame completely behind the spring seat. It is not a stretch to have the spring completely fall from between the axle and frame, as there is no lateral support for the spring.
There may be some drop springs that will stay in contact with both spring seats even with the rear axle at full extension. The ones I have are short, and will fall out of position with the rear of the car jacked to change a tire.
I did make these and welded them on along with the front brace. I made them from 1X2 inch flat stock and drilled & tapped them. Holes line up with stock and I have 3/8th inch ARP small head 12 point bolts for it.
Mark: snowman-33
Nope. But as with any woman whose been neglected she'll need more attention than you're showing so far..........[snip]I swear this car does not want to return to the road!
Hey Ken. I've looked at them before. I appreciate the link but I have so much steel laying around just waiting for a project. Thanks.
