Finally back to working on the wagons...
On the 1994
On the 1996
I found my multi-meter which saves me ~$400 for buying a new one!
Spring and de-salted roads are near, so I better get this finished up.
On the 1994
- Took the snow tires off and put the all seasons on
- Fiddled with the rear brakes to see if they can be more consistent (not really)
- Greased the front end components
- Checked the fluid levels
- Gave it a bath
On the 1996
- Checked the toe - it looks off visually, but measures good. Checked the fixtures I made and they're good, re-checked toe and still good. Must be an optical illusion
- Found a place for underhood power distribution and relays for the horn and other future accessories since I'm not de-soldering the board shown a few posts above
- Got quotes for 45 tooth ABS hubs. I need to just pull the trigger on these and get it done.
- Updated my "open items" and "things to order" list
- Installed the Crank Case Vent Oil Drain Line from the CCV to the Oil Pan. There's a steering shaft in the way of the original routing shown in the picture below so I ended up re-routing the line so it goes below the valve cover to the front of the exhaust manifold and then down instead of outside the manifold. No pictures of it in the car - can't see it
