1 - 20 of 26 Posts
1993 Chevrolet Caprice Classic Driftwood Metallic 5.8 Vortec TBI
Motohorn has anyone used something like this?
I had 4 note horn setup off a Buick or caddy for a long time but 2 notes went out and I replaced with 2 regular delco (now have 2 hi and 2 low) replacements and it’s decent but not the same presence as the 4note was
You can order the horns individually. You just have to make sure you know which horns you want. Or just order all 4 at once - you need the A, C, D, and F notes.
From where? few years back, the two unique to the caddies were long discontinued.
Whups, I didn't think about that. I found a bunch of sets on ebay, but looks like the going price is around $150.
I pulled the horns off a Caddy in my local Pick n Pull, paid about $15 for all four of em. One of the best mods I've ever done to the car lol, sounds like a train.
A stock Caprice/ Impala has two, A and F, so one would only need to buy the C and D notes to get the full 4 note setup. (I do know OPs horns aren't stock) They also have the notes casted into the horn body, which makes it easy to identify them.
I don't know what it is with you idiots, now you've got me researching this and I don't even have an impala any more. :rolleyes:
Anyway, I found a video of a guy playing each note individually. Turns out the C and D notes bracket the A and the F, with the D being lowest and C being highest.
D - 294 Hz
F - 349 Hz
A - 440 Hz
C - 523 Hz
Of course, that assumes the horns play perfect pitch. But at least, you know that if you buy a horn in the 300 Hz range and one in the 525 Hz range, it will approximate the caddy sound when combined with your stock A and F horns.
This is a favorite of mine.
I got my horns off a similar year
  • Like
Reactions: 91ss
Turns out the discontinued high C caddy horn, has a near replacement in the BMW 525 high tone horn. The bimmer horns are 410 and 510 Hz, pretty close to the 525 Hz high C caddy horn.
I doubt they do.... The optioned "C" ,and "D" horns plus the standard A ,and F horn
notes makes a huge difference. As does placement of the horns themselves.
  • Like
Reactions: Marky Dissod
The low D horn is still available, for some reason they discontinued the high C, thus the bimmer sub.
Most of the ads I see tell you which note it is. The AC Delco horns have the note stamped in their metal, and a lot of the newer ones have the actual frequency in hertz stamped in them. Check Oreilly Auto and Amazon.
Keep an eye out at salvage yards for late model Cadillac's ,fullsize Buicks ,and maybe Oldsmobiles.
I've gotten lucky there in the past. I need to inventory my stash of GM horns ,and may part with some.
I was able to find all 4 notes in a 90's Buick LeSabre Ultra (3800 FWD). Have not had time to install them yet. Might try to find another set and install a pair of each. Can't justify the $4k for what I'd really like to have (and it would probably get me in trouble anyway...)
Caddylack - not sure how the horns differ (if at all...)? I believe on the GM horns, the letter is molded in the plastic on the outlet of the horn. The letters are pretty "thin" so can be easy to miss.
1 - 20 of 26 Posts
