Pulling the interior out to clean and redo. Found this attached to the vent in the center of the dash board. What does it do?
Just out of curiosity, why have you deliberately avoided using the T/S?Thanks, now I dont have to worry about mounting it to the vent since I broke the tabs. I have never used the TS on purpose.
Are you saying that with T/S on, the lights come on because of being in the garage (makes sense, but they also stay on when you get out in daylight?I'll use it to turn the headlights on, but being that I park in the garage, if I'm not paying attention (which is pretty damned often) they'll automatically be on the next day while just cruising around town.
No, they'll turn off after a while. I just prefer not to drive around with the lights on during the day, even if it is only for a few minutes. I use the T/S at night mostly just so I can be lazy and not worry about turning them off when I park the car.Are you saying that with T/S on, the lights come on because of being in the garage (makes sense, but they also stay on when you get out in daylight?
If so, something's wrong. Once the sensor picks up enough light, the module should turn off the lights. That's how mine has always worked and how T/S works on other cars I know.
Maybe you just need to clean your sensor? I do that every couple of years. Nothing fancy, just a screen cleaner soaked paper towel and dab-twist it a few times.
No, they'll turn off after a while...
