Im getting close to sending my PCM in for a tune, is there any little cheaper(less than $50) upgrades I should do to my car before I send in the PCM that would make a difference in my tune? Right now I just have a stock LT1 with a KandN with 125k on it...Also any certain parts of the tune I should do for sure on just my stock motor with K and N?
My goal is just to have an overall better running car with a little more "pep" to it...Right now the shift points seem a little odd/car at WOT pops, I did a search and found it may be the rpm limiter...
BTW I have a 95 SS.Here are some basic questions Before I contact PCMperformance
Like removing the Vats, would this help as far as an alarm/remote start install is coming soon(I ask bc bestbuy charges like $60 more for a Vats bypass)?
RPM/speed limitors, Speed limiter gone for sure, but RPM limiter? I think mine pops at WOT....
POWER TUNE= spark timing and fuel maps customized for maximum performance - Sounds like a good idea???
Changing the Octane really necessary/benefits?
Obviously do the lower fan on temp setting correct?
Even mess with shift points?
Any other Ideas? Thx for the help as always....
