hey Boston11,
Here are the changes I did:
Cam, from Comp 304 (210/220) to Comp XTreme (224/236)
Converter, from 12" 2400 to 10" 3800 billet
Tranny, from 4L60E to TH400
My previous best:
NA -- 13.52 @ 101.63
N2O - 11.90 @ 114.25
My new goals:
NA -- 13.17 @ 103.6 (+0.35 & 2mph)
N2O - 11.57 @ 118.5 (+0.33 & 4mph)
But it has to be a 50 deg day for this to happen, same as my previous best. This will be my last attempt with a near stock 350 LT1 block. By near stock, here is what I mean:
Stock block, crank, rods, pistons, bearings, oil pump, oil pan, gaskets, and all bolts
Stock intake manifold, injectors, fuel rails
Stock water pump, optispark
Stock valves, lifters, pushrods, chain, gears
Stock iron heads with mild porting and stock valves with 3 angle job
Aftermarket cam, rockers, springs, valve guides and studs.
