I put some Hotchkiss springs and billstein shocks on about two months and a half ago. Over the past three weeks or so when I drive my impala I have been noticing a loud popping noise coming from my passenger side around the wheel well area. It happens somtimes when I hit a little bump or even when I turn sometimes but not when I am riding on smooth surface. Does any body know what might be the problem
did you check the rear control arms, hopefully the rear springs were put on correctly :eek:
Well if I take the wheel off what should I look for to show that it was put on right. SHould I compare both sides. I drivers side doesn't make any noise and seems fine.
