1 - 9 of 9 Posts
T
Ok my set up is:
2 Cerwin Vega Stroker 12's and 1 5000w BOSS Blade. I only have one sub hooked up to the amp currently and it sounds horrible. All three items were brought brand new. The amp i cot off ebay listed as NIB not refurbished, and it arrived that way. What do i need to do to get these things to knock like they are supposed to?
T
correct positive is to positive and negative is to negative.... the enclosure is just a wood box that had the depth that speaker manufacturer suggested. When i first hooked it up they, well i have only hooked one up at a time, they would hit but after blowing a couple fuses they don't do anything.
U
You're blowing fuses? Main power fuses or on the amp it's self? How ungodly high is your gain?
T
Main power fuses... Only think i've done with gain is turn it down.
T
Is your box ported or sealed and did someone make it or prefab?What size fuse are you using on your main power wire?
1 - 9 of 9 Posts
