Found a set of 1994 Sawblades on my local Craigslist. The rear wheels are 17x9.5. One inch wider than the stock Impala wheels I have now. I know the backspace and offset comes into play also, I just don't know where. Does anyone out there know if they will fit a '96 Roadmaster? Thanks
If the offset is correct, they will fit. If they have 1/2 inch more inside hub to rim than your stock ones (straight edge across the inside lip, and measure to the hub), they are right. More or less, and they could rub.
