I have a 77 2-D Caprice. What is the lug pattern size? I want to buy either 16 or 17 inch wheels that will be about 8 or 9 inches wide. I'm not sure what the offset I should be for wheels of this size? Thank you for your help.
77 is a 5 on 5 bolt pattern, I'm about 99% on the bolt pattern size for that car. Or you can call discounttiredirect.com and they can tell you.
Mike
1977 is a 5 x 4.75 bolt pattern, unless it is a wagon or 9C1 which would be a 5 x 5. Since his is a coupe, it is definitely the 5 x 4.75. 1977-1990 were the same generation car.
Sleeper, I do believe you are correct! Thank you gentlemen.
