LT1 to 383 rebuild - Trick Flow 195 Gen X Heads - CompCams LT1 XR276HR12 - 32lb injectors - 1.5 Rock
Working to update the rear tires and stance of my 96'SS.
I am widening the stock 17"x8.5 to 17"x10.5" so I can safely install 315's
Currently running Mickey Thompson Street Comps all the way around on stock wheels - MTT-6275 - 275/40R17 - Mickey Thompson 6275 Mickey Thompson Street Comp Tires | Summit Racing
Updating the rear to MTT-6278 - 315/35R17 - Mickey Thompson 6278 Mickey Thompson Street Comp Tires | Summit Racing
From my measurements (see attached sketch) it should be close if I add a 1/2" spacer to the drivers side - Wheel Adapters, Wheel Spacers, Hub Rings for your car! | Motorsport Tech
If not I will notch and box the frame.
My question is . . . do my frame to fender measurement look representative to other 96'SS?
We all know nothing is square back there and cars are typically offset in some way . . . just looking to hear if my car is within the norm in comparison to any of yours.
Attaching pictures of my notes and my not to scale drawing for comment.
Thanks in advance for the input.
PS - in the process of updating the pair of stock wheels to 17"x10.5" rear wheels. If they turn out and test well I may run six 17"x10.5" wheels, refinish so they look factory new and sell 3 pairs to help offset my costs - as you can imaging this is not a cheap process and in retrospect it might have been better to order custom wheels that look like our stock.
Direct message me if you might be interested in updated stock 17"x10.5" alloy at [email protected]
