My car makes a clunking noise and the steering wheel wobbles. It started happening after I was taking some curves on the highway at high speeds. It does not do it when I'm going straight or turning left. Any suggestions?
Check the alignment shim packs in both upper front A-arms. If the bolts get loose the shims can fall out causing the symptom you describe. It happend to me right after an alignment. If that is not it I'd check the sway bar bushings and end links next. The metal in the crossmember is not real thick and spirited driving can pull a bushing bolt right out.
