1 - 9 of 9 Posts
I'll be getting an SSRI soon and was wondering if I should get an F-body Maf at the same time. Would it be worth it with my mods? I'll be getting 1.6 rr's after that. Heads and intake untouched.
Thanks.
You'll likely need to do this after the 1.6 RRs and a 52mm TB. But I don't think it would hurt to do it sooner. As I understand it the B-Maf is the next big restriction if you've got a good induction system like the SSRI and have installed 1.6 RRs.
HTH
I don't think its necessary until after big heads and cam, blower or a stroker. You are not flowing enough air through the motor to NEED an F-MAF with just bolt-ons.
If you don't have a better exhaust, headers and intake, do that first and don't waste your money on the F-MAF.
FYI, you need to reprogram your PCM for the F-MAF.
Right... A larger TB, 1.6 rr's and better cold air system hardly necessitates a larger MAF... The engine can only use so much air. Once you are making 300 RWHP, then consider a larger MAF.
We did Dyno tests on this several years ago, and the only cars that it helped out on were the HEADS/CAM cars... One car with a crane 227 actually lost 2 hp... I gained 12hp. Another bolton car gained Zero.....
Cool thanks, just checking. The reprogramming wouldn't be an issue and I guess I forgot to say that my CIA tubbies are being sent on monday. Not sure if that makes a difference.
Maybe after the SSRI I'll just start doing suspension mods. Any Input on weather i should start looking there on a car with as many miles as mine has?
I am still running a stock MAF. I figure I'll get myself ready to do the bigger TB and MAF at the same time, that way I can go to the track with the laptop, make one run, swap MAF sensors, program, make another run, swap TB's, make a run (I don't need to reprogram for a TB...yay T56), then swap back to the stock MAF and program again and make a 4th run. If it's a good day at the track (not too many people), I'll try to make a couple runs with each setup. That way I can report back which one was the bigger gain, and what the 2 together did. I just need to decide what companies TB I want to run...if I don't just have my spare stocker machined out to 52...all depends what size TB I want I guess. I think a 52 will be more than enough for my current setup, but do I want to go bigger for future engine plans (likely on an LT1 in a cleaner nicer car) or not...time will tell. That said though, I don't think you should worry about the MAF yet...Noel is a smart dude to listen to now and then.
Something told me this was going to be a somewhat divisive subject with differing view points. FWIW, I waited until I had done just about every other bolt-on mod and when this was the only one left I did a search. I believe this was the thread that convinced me to go ahead and get the F-MAF linky. Read down toward the end for the flow rates of the different MAFs.
One other note, with all the bolt-ons (most notably the TC) I am putting more power to rear wheels than my stock LT4 vette, which has a 3.5" MAF. I think that it really depends on a lot of factors as to whether or not you need the bigger MAF. I believe that in my case the F-MAF was the right choice! Fact is, they're cheap (I paid $60) and with programming there shouldn't be any negative impact.
Oh and yea, I like o'l Noel too, he's a really Fart Smeller. :D
1 - 9 of 9 Posts
