K
I am going to install my Bazooka tube tonight and wanted to know where is the best place to run the power wire through the firewall. I took a quick look last night but I did not see the usual empty hole with the rubber grommet/cap in it.
for any info
If you pull back the carpet on the passenger side you will see a hole in the firewall leading to the engine compartment.
T
On the driver's side there should be a 2" (or so) rubber grommet with wires coming out of it on the firewall under the steering shaft. In that general area anyways. Ya can't miss it.
Good luck.
