1 - 13 of 13 Posts
Looking for a new expansion tank as I noticed a crack on the seam of mine. As long as it's out, I'd like to find a gm/Delco coolant gauge sensor. Any leads or part #'s?
Found expansion tank for $98 shipped on eBay. Gm part #12528777
That's how much I paid at my local Chevy dealer. Might as well try there first.
Guessing gauge doesn't work. Though broken/damaged wire is most likely the cause.
Yeah tha gauge works properly once in awhile, but mostly stays at the halfway mark and goes up from there as the engine warms up. The wire is intact.
Discussion Starter #10 (Edited)
That is the part number that Hamilton Chevy sells listed to fit Impala SS and the same number I bought and installed on my Impala.
Yeah, I called them and they confirmed its the correct one but weren't sure why it said it wouldn't fit. Same price as some used ones I was finding so I ordered it.
Mine temp gauge pegs when unplugged, acts right 10% of the time, wire is intact and not frayed. Found these #'s
GM PART # 25037332
AC-Delco # 213-77
Well I put the new sensor in for the temp gauge and it still reads almost to the red 90% of the time. Wire is all intact, has an insulated butt connector about 8" down the wire that's good also.
Discussion Starter #13
do you have a IR temp gauge to take a temp reading?
your dash gauge may be FU
Yeah, actual real world temps are right where they should be. It's just the gauge reading incorrectly. Just got a new plug for the sensor today so I'll put it on and check back.
It it's the dash gauge, I'll look for a new cluster since the volt gauge is steady pegged at 18volts too.
1 - 13 of 13 Posts
