I read a post where a member said they had "real" 2nd gen F-body front sway bars... is there such a thing and who sells it?
Creep
K
If by "real" you mean produced by GM, you'd find those at junkyards. GM doesn't sell them anymore.
If by "real" you mean exact same specs as that bar just a different color, call national parts depot :D
Thanks KnightShade... is it best to get the original restoration part or an aftermarket substitute?
Creep
K
They're identical parts (cept for the color). If you don't mind going through the work to clean up a bar from a junkyard, and you can tell if the bar is unbent/undamaged or not from a junkyard, I've heard them going as cheap as 20 bucks... If you just want a bar to show up at your door in brand new condition that you can just put on with no work, spend the extra 100 bucks at NPD.
D
Does the NPD bar come with mounting hardware like BMR for instances?
Knightshade,
Is there a difference in the sway bars through the years 1970 to 1981?
Creep
W
<BLOCKQUOTE>quote:</font><HR> Is there a difference in the sway bars through the years 1970 to 1981? <HR></BLOCKQUOTE>
I can't find my F-body references.....but, I -think- you need to find a front bar off of a '77-81 WS-6 Trans Am.
Look for the 4-wheel disk brakes, snowflake wheels,(probably gone), "real" Pontiac engine,(vs Old's 400).....
