i've had my ST springs (2" inch drop) installed all the way around for about a year. just swapped the front shocks with cheap Gabriel Ultras from autozone but wanted to get the "shorter" rear shocks so my springs don't fall out of place when i raise the vehicle in the back (common problem with ST springs and stock shocks)
where could i get a good price on shorter shocks? nothing fancy just replacements. tia
J
I sell toxic shocks (made by explorer pro comp)
Those are the ones I used on my SS I just measured the stock ones and went with shorter ones they work fine.
what rear shocks are other imp owners with ST springs using?
I've got ST springs and am running Bilstein 1104/0929. Some places will try and sell you the heavy duty shock for the rear but you need the sport shock. Personally I would have gone with Koni's but they are really expensive, but they do have a lifetime warranty and the fronts are adjustable. Not to step on your toes Jimmer, but shox.com is where I got mine. The second pic in my sig is during shock/spirng install.
