I know the stock design is supposedly weak but what do you gain by going to aftermarket LCA's? Can the car launch harder? Why? How does it affect cornering?
K
Well, one problem is that the larger aftermarket rear sway bars will -destroy- the crappy stock control arms. That's a fairly good reason to upgrade
But yes, you'll launch a bit better too, less bind, etc...depending what kind you get... I mainly stoplight race so I spent the extra $ on the global west arms, best you can get and no bind thanks to the kinds of bushings they use (spherical aluminum on one end, del-a-lums on the other)
