Im having a problem with my ss when i go start the car it cuts right off they told me that it could maybe be the iac sensor can that be true? if some one could help me out thanks!
1996 Caprice 9c1, 2018 Ram Laramie CC 4x4 EcoDiesel , '03 Ram 3500 Laramie Sport QC 4x4 Cummins
It could also be something as minor as a loose air cleaner assembly. If you have a loose clamp on the air intake system,it will do the same thing. If you've got a stock air cleaner and just checked the filter and didn't get the housing on all the way,the car won't run. I had a 4.3 liter Caprice with a bad gas cap and the car did the same thing,start and shut right off.
You really need to provide more info about your car. Year,miles,any recent work done,is this car new to you. You get the idea.
yea bro i took a good look at it and it was the elbow that was loose, i should look better next time.lol thank you for your help.
