Usually the tire is the determining factor. If you put wide tires on a 10 inch wide rim, they can hit the body, or frame. 11 inches sounds like a good maximum width. I have heard of 275, and 295 tires fitting under the body. The 275 is about 11.25 inches wide, and the 295 is about 12 inches wide. The sidewall height should be limited to 2 to 2.5 inches with the 22 inch wheels (26-27 in dia.) to keep your speedo accurate.
  • Like
Reactions: Lance
