Where can i purchase the felt/weather seal for the 4 windows (for the interior side? Or how can I restore the worn seals that I have (felt wore off). Any ideas or direction would be great!
The only place I can think of for getting the seals is off of another door panel. You must use heat to soften the melted tabs for removal and carefully swap the parts. Pick panels that are otherwise broken. Any B body felt strip except the RMS rears should be compatable. I will probably hit the JY on Sat. or Sun. and can check for a set.
