D
I'm installing a Viper 791xv with two 530T window modules. Does anyone have the wiring diagram for these modules, or know where I might be able to find it? Thanks in advance.
www.directechs.com
might have it. Some of the info they give to anybody, and the other half you need a password....I'm not telling.
:D
Check it out, they do have alot of archived information.
D
Thanks xSSive, a friend used to be a tech and had the password, but said it was changed not too long ago. Hopefully they have the info, thanks again.
**EDIT**
You must have a password to get any information. Anyone have access that can get this information for me, it would be greatly appriciated.
D
Anyone have programming information for DEI Window module 530t?
I have access send me your e-mail and I can send it to you. The tech data I have from directechs is 8 pages.
no problem. I help whenever I can. I know a database like that one could help get people out of a jam. I have a directechs acct so I can try to help.
N
hey did you get it figured out, i have a 791xv and the 530t window mods in my ss, also have them wired to my motion sensor to roll up the windows on a motion sense if the alarm is armed... i can tell ya how to do that as well if you like, dont forget to wire in therelay disconnect for shock sensor on window rollup and you have to set the mods to the highest resistance setting for the windows to work efficiently. i put the mods inside the car in the driver kickpanel behind the ebrake pedal and ran the wires through the boot. the great feature of this is the express window roll up and down.
