The driver side window wont roll done unless its wet. I think its the tint but all the other windows roll down with no problem.
I notice its getting caught up on the stripping when it comes down and the only way I can make it release from the seal is if I knock on the upper part of the panel.
Any suggestions?
There are seals all around the window which one are you referring to? The track may be sticky, spray some silicone lube on the track. If it is the strip across the top of the door, they can be replaced, bit it is difficult and requires some modifications.
Its the bottom seal thats above the door panel...I can see it buckle down and grab the window as it works its way down...
