My passenger window will go down with the switch. It dose not work on the drivers side eather. I have change the motor (3 times) still will not work. When I used a check lite
it works fine (the lite) Still no luck. I have tryed everthing I know of./Can't get the window to work Help
Did you check the wiring between the switch and the motor? You may have a broken wire.
