1 - 11 of 11 Posts
OK, those of you that use your Impala SS for a daily driver and have to drive in the winter where you actually get snow and ice, what do you use for wheels/tires? I know a taller, skinnier tire is better for winter driving and wondering if I could get like a 9C1 wheel setup and put dedicated winter tires on there to run in the winter.
Or, since I am planning on getting a nice set of aftermarket wheels and tires for the nice weather, is there a good, dedicated winter tire in the stock size that will work on the stock wheels?
Any and all input welcomed. Could not find the answer I was looking for with the SEARCH function. Will the stock Caprice or 9C1 wheels fit on the Impala without a problem (since the Impala has the wider rear end)? Any other suggestions? Tire Rack does not offer a winter wheel/tire package, just tires.
Cheap (but decent looking) 15" steel, Pacer Redline wheels and Blizzacks. Two Winters and they have served VERY well so far.
My car came with a set of these;
Eagle Alloys with 215/70-15 Blizzacs. The previous owner had them on steel 9C1 wheels before he had them mounted on the alloys, about a week before he sold the car to me... He said the Blizzacs were great in snow, but I did not need them for some reason. Sold them on ebay.
So, is the 215/70-15 tire comparable to the stock 255/50-17 so there is no ill effects on the ABS? Any recommendations for offset for a 15" wheel? I assume then that the stock 9C1 size wheel will work, too?
Boilermaker,
Where did you get those Pacer Redline wheels?
Originally posted by Wayne Bengston:
....He said the Blizzacs were great in snow, but I did not need them for some reason.
You mean you had better options for all the snow you get up north.....in Houston? :eek: :eek: ......
KW
KW
I find that the Kumho 712s work just fine in the snow we get here in Houston.
The 215/70-15 is 26.9" diameter vs 27" for the stock tires. Virtually identical. ABS only cares about mismatched tires anyway. As long as they are all the same diameter, it's as happy as a pig in ****.
5" seems to be the consensus on backspacing. Be aware that some 15" wheels don't clear the rear caliper. 9C1 wheels, of course, do.
Yeah, pretty sure the 712's will not work with the snow and ice we get here in Central Iowa...
So, 15" with 5" backspacing. And I will be just fine if I can find some cheap take off 9C1 or similiar wheels and pick up the tires.
342B Black Daytona Wheels. Picked them up at a local tire store for $60 each including mounting and balancing (were covered in dust hidden in the corner of the showroom).
Discussion Starter · #9 ·
Also, American Racing Wheels 767 :D ! Got mine from Dicount Tires....about $60 each these days....
These are the black wheels with the red and blue strips on the lip.
KW
Or you can go to the junk yard like myself and pick up some rims. I picked rims from an Astro Van, It has the same 5x5 pattern as the stock wheels. I cleaned em up and painted them. I put 255/60's on there which worked fine for the winter task. Only got stuck once o nIce and needed a nudge to get going again.
Pualy.....Moderator says, "read this" >>>> http://impalassforum.com/noncgi/ultimatebb.php?ubb=get_topic;f=22;t=003528
[ 05-15-2005, 11:04 AM: Message edited by: KW Baraka ]
1 - 11 of 11 Posts
