Bonneville Arms and Bosch Blades Installed
I got all of the parts a while ago. I cleaned, prepped and painted the arms with a satin black chassis type paint. Hopefully it will hold up to chips since it's chassis paint.
It took some coaxing but I finally got both caps off of the OEM arms. After 16/17 years, those things were really stuck in place.
I went with the 22 inch for the driver's side and 21 inch for the passenger side as one of the early posts in this thread suggested. Whenever I have to replace these, I will go with 21 on the driver's side and 20 on the passenger side. The ends of the blades stick out over the edge of the windshield a little too much for my tastes when using 22 & 21 since these Bonneville arms are a different length than Impala SS/Caprice stock arms. At first, I thought that I had made a mistake installing the arms on the wrong sides of the car but I checked and I put LH on the driver's side and RH on the passenger side.
I have only used the washers a couple of times so far. I expected to be blown away by the extra nozzles but I wasn't. It wasn't two big wide spray patterns from each arm. Perhaps that means that my washer pump is getting weak after 17 years?
The wiper operation seems to be good. We'll see how well they work as Northeastern Winter approaches!
