I have this troublesome problem now, I heard they are called "tears of joy", but i wanna see when I accelerate..
is there some form of gm checkvalve I could put on my wiper lines?
Unless you use the windshield washers regularly, just pull the hose off at the pump, drain the line and reconnect it.
Where is that check valve located? Underhood or back by the tailgate?
Jim
Right off the wiper tank... But I doubt it would help the issue. The check valve is designed so fluid cant drain back to the tank
