my 96 roadmaster wont roll over or anything. when i turn the key on the pass key light blinks. tried my spare key and get the same results. what can i do to fix this?
I had the same problem with my 95 buick rm estate. All I did was check the ignition switch take off steering wheel to get to it and pull off turn signa switch to get the the ignition cylinder look at the two white wire running to it and check to see if the are frayed or exposed this would cause it to ground out when attempting to start the car. This happens frequently with the passkey in the 91 to 96 gm cars.
Sent from my Venture using AutoGuide.Com Free App
