I'm changin the suspension up a bit and I want to know if ST rear springs would be lower than the intrax I have in there right now. I dont want to have anything lower than what I have b/c I am going to have weight in the trunk which will lower the back even more and I have wheel spacers in the back that push the wheels out ALL THE WAY so I dont want rubbing problems.
I'm pretty sure ST is constant rate and intrax is progressive also
Not sure about Intrax ride height, but I'm running ST's in rear on stock size wheels and tires (27"). The rear sits at 25 1/2" pavement to center of wheel well. I would NOT want to be any lower because rubbing issues would follow. If you go with ST's in rear make sure you have lowering springs in front that match or the car will look as if it's dragging a load all the time. So far, I'm very happy with the ST springs in front and rear.
