BBK is preferred, the old style so I can swap the top plate.
Let me know if you have one laying around and/or want to get rid of it.
Thanks,
Chris
Used a service like this that used to list on EBay. He included powder coating too and had him powder coat it Gray....still looks great today. Even was able to bore it with the Airfoil that was added.
Another thing to consider when swapping your TB and if you did/or will do the Bypass hose mod, cut the IAC housing. This just cuts off the section with the metal tubes to clean up the bottom of the TB. There are some that sell these IAC housings already modified .
Well I was able to score a 52mm and 58mm BBK on another site.....now I am just not sure which route to go. I will end up selling the other one
58mm are way overkill unless you're making big power (north of 400-450hp.)...
