Okay.. This is an odd ball (Maybe)
Does anyone have good air ride air compressor drier Canister and a short piece of air line that attaches to the top from a 94-6 Caprice or Roadmaster wagon?
I need this.. A small spring clip holds the canister on. Its easy to remove when you turn it a little, Pull it out w/ some pliers or knock the back of it out w/ a screw driver. Remove the compressor, 2 8mm bolts, Remove the spring clip, Pull, Get the canister off and a piece of air line w/ the factory fitting.
I need the piece in red.
Below is the part I need.. Small, Easy to ship.
Airline goes there. Will not be a double connector as seen.
FYI, a few years ago when I had issues with the compressor on my '93 wagon I went to the yard to try to locate one. While searching I discovered the compressor itself is the same as the ones used from the '70's on up. The ONLY difference I could find were the mounting brackets, but they are easy to change. You might try your local yard and start looking at Cadilliacs, Buicks, Oldsmobiles and others that used the air shocks.
