I want a good-no breaks, bottom for my heater-AC box/housing. The type I need does not have an extended area near the drain tube. --"94 Caprice"
"Correction -I can tell it is there"
Thanks but I do see the bottom piece in the pic. The section at top leaning against the jack stand is the box containing the evap. & heat.cores. are you willing to remove the bottom? I was told there are 2 different units (bottoms) so I need to see it to compare.
