My connector is shot. I need the connector with some length so I can splice into my harness. I think its the low side, its the connector close to the radiator/evaporator.
That's the high side pressure sensor that goes to the ECU. Pin B (GRY) is +5v, Pin A (BLK) is ground, Pin C (RED/BLK) is a 0.5-4.5v signal back to the ECU.
The wire colors don't matter - just do them one at a time position for position. The new connector will have A, B & C molded into it to denote which one is which - I'm reasonably sure (from memory) that C is the 3rd pin - the one that is twisted 90 degrees from the other two.
https://www.bmotorsports.com/shop/product_info.php/products_id/502
Staring into the plug end of the pigtail as in the picture below with the center up .
left lower A
center C
right lower B
look closely, the plug is marked
A is Black circuit 452 sensor ground
B is gray circuit 416 sensor 5 volt ref
C is red/black circuit 380 signal
( edit, pretty much summed up in post above )
