I'm looking for screws needed to mount hood and grille assembly. Hood latch screws and grille assembly mounting screws. Thanks
I should have most of them. Have you tried the local auto parts store? The only ones that are odd are the side bolts at the back for the hood, and the grille screws with the torx heads. A phillips head screw that has the same thread as the torx would work for the grille. I have seen hex head bolts used at the sides of the back of the hood. As long as the threads are correct, you should be able to find 90+% of them at the local auto parts store. The bolts are all metric, and the screws for the grille are about a size 8 sheetmetal screw. Let me know if you can not find them locally.
