Driver's side reverse light went out, so I tried to install a new one but found a bunch of yellow goo in the socket (looked like some kind of wax). I put the new bulb in but it did not work, so I checked the passenger side and it too had the stuff in the reverse light socket. I've not seen this before. Is it normal?
Like goldy said, its anti-corrosion grease. My front side markers did not have this in them and it was a PITA to get the bulbs out. Basically had to break the bulb and use needle nose pliers to twist. If you put in new bulbs and they don't work, clean a little bit of the contact off, but leave the rest. It won't hurt at all.
You can buy tubes or packets of dielectric grease at Autozone
