You who have there stock oil pressure reading real pressure,by removing the resistor and installing the 0-60# sensor,,,,,What does the gauge read when at idle and driving, hot & cold??? I think I would like a 0-45# sensor so the gauge reads higher...Oldhead...This is the third time I am asking and if I do get a answer I am going to hurt somebody
Dont want to see you go out and "hurt somebody" so will do my best. >
I have modded my 95 to remove the resistor and just went with the Stock 9C1 sensor which is 0-80 PSI. I also have the Z-28 Cluster which the gauge has numbers of 0, 20, 40, 60, 80 (IIRC) and the needle is about 55 when cold and can drop down to 15 PSI when warm and idleing. The only other sensor I know of that people use in place of the 9C1 Sensor is the Truck Sensor that is listed in the mod. This sensor is rated at 0-60 PSI.
But as you eluded to, this does NOTHING to affect the oil pressure, just changes on the Gauge where the needle points. For example, if your Oil Pressure is 40 PSI....the 9C1 sensor will have the needle in the Middle of the gauge. if using the Truck Sensor, then the needle will be at about 2/3rds over. A 45 PSI sensor will move the needle even further to the right, but again just changing your perspective.
Not sure I've seen one listed or that another is KNOWN to work with the circuitry of the current Cluster/gauge. If it were me, I'd just go with 1 of the 2 (9C1 or Truck) sensors or feel free to try different sensors and hope you can find 1 that works. At least you have an idea of how it should read in relationship to the SWEEP of the gauge needle. Keep in mind that using the Stock Caprice Cluster, you aren't looking at numbers on a gauge, just somewhere in between L and H. But you are changing nothing other then where the needle will line up under certain pressure using a specific Sensor So I guess my question to you would be....Why Bother?
