·where can i find a set of zq8 bumpstops at and how are the installed,also what do they look like?
Mine came with new nuts in the box. Good idea to use some loc-tite when you put them on.Originally posted by Vlad the Impala:
Note that you have to buy metric nuts for the ZQ8's. The factory bumpstops are SAE.
I have Eibach springs. The bump stops contact the frame and compress just at the tip.Originally posted by Vlad the Impala:
Also, depending on how high your suspension sits, you may have to trim them. I have not found a concrete answer on how far they should be from the frame, but it seems that people are typically trimming them so they are 1/8" from the frame when your car is sitting level. That is what I did, but I don't know if that is right.
