Smog Pump Bracket - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 12-15-2014, 10:09 AM Thread Starter
Smog Pump Bracket
So I'm trying to switch out my water pump and I go to remove the smog bracket. Everything I've read and seen has shown two bolts for this but on mine there looks to be a third one behind the spark cables. Am I seeing this right? I took the two bolts off and the bracket is very tight.
Part no. on the bracket: 10215680A
95CapriceClassic is offline
post #2 of 4 (permalink) Old 12-15-2014, 02:40 PM
You must be missing a bolt. IIRC and its been a while, just remove the bolts and it pretty much fell off the engine block. I have mine at home that I can take a closer look at later if you need it.
Did you look at the "remove your airpump" thread or even just take a look at another bracket? That should pretty quickly show you where the missing bolt is. Here is a pic of all the parts with the bracket and may help you find the missing bolt.
https://www.impalassforum.com/vBullet...9&postcount=29
post #3 of 4 (permalink) Old 12-15-2014, 03:18 PM
Founding Member
Area 51 Perf's Avatar
Theres a bolt holding the AIR pipe to the back of the bracket . You can just see the tab coming off the pipe where the spark plug holder is. Takes a 10mm wrench por socket. There is also another bolt down behind the spark plug wires by the OPTI.
Remove those two and the bracket will pull right off.
ECTM#1
East Coast Troublemakers
Disclaimer:
The poster does not take any responsibility for any bad feelings or sense of exclusion that the reader of this post may have-whether real or imagined. Reading threads poses inherent risks. The poster of this thread would like to also remind readers to make sure they have a functional sense of humor and a brain before they visit any discussion board
Area 51 Perf is offline
post #4 of 4 (permalink) Old 12-15-2014, 07:27 PM Thread Starter
Thanks all. We figured it out earlier. There's nothing in the Haynes manual or videos I watched about those additional bolts. Luckily my friend was able to get that back Opti bracket off. I could not fit my hands back there. Mission accomplished.
