1991 Caprice 5.0l - Heater Control Cable - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 02-27-2015, 09:50 AM Thread Starter
Continuing the restoring of my late Dad's Caprice .
No heat ! :-(
The lower horizontal lever on the Climate Control Center goes from cold to hot . Nothing happens . I re-attached the left end of the cable to the Climate Control Center . Still nothing .
My understanding is the other end of the cable operates a blend door , inside the heater ?
I need info , photos and / or pdf's , please .
Thanks ,
Wyr
God bless
WyrTwister is offline
post #2 of 5 (permalink) Old 02-27-2015, 01:20 PM
The Fooser Guy's Avatar
http://s368.photobucket.com/user/The...?sort=3&page=1
https://www.impalassforum.com/vBullet...d.php?t=254478
Both should help...
The Fooser Guy
The Fooser Guy is offline
post #3 of 5 (permalink) Old 02-27-2015, 02:06 PM Thread Starter
I think I need to investigate the mechanical cable from the Heat / Cool Selector to the round assembly on the plastic housing ?
Thank you ! :-)
God bless
Wyr
post #4 of 5 (permalink) Old 02-28-2015, 07:28 PM Thread Starter
1991 Caprice Heater
It turns out my heater - A/C " box " looks a little different than the picture , But the picture was still very helpful . :-)
Thanks
Pulled off some of the plastic lower dash panels and the ash tray / cup holder off . Located the mechanical cable that operates the cold - hot blend door . Re-attached the cable and now I can hear the blend door flopping about , when I move the control lever on the Climate Control Center !
Praise the Lord ! :-)
I also tried to replace the black plastic vacuum operated hot water / coolant valve . I tested both the new & the old valve & looking in one of the heater hose ports . I could see the inside part of the valve moving when I applied vacuum . Unfortunately , I broke the new , plastic valve . It was getting late , so I re-installed the old valve .
No joy ! :-(
I have been having vacuum problems . I had to run a new vacuum line to the controls , to get the system to change from each of the heat , cool , vent , defrost functions . I also ran a temporary new vacuum line to the water valve . This did not seem to help . No hot / warm air . :-(
Then it occurred to me that the logic of the controls may be the opposite to what I had guessed . I removed the temporary vacuum source from the water valve & I started receiving warm air from the vents !
The air was not hot . But it was warm , a HUGE improvement !
I do not know , it may never get hot ? And I may still need to work on the vacuum issues , when it gets warm enough to no longer need heat ?
But that is something to address , at a latter date .
God bless
Wyr
post #5 of 5 (permalink) Old 03-04-2015, 09:41 PM Thread Starter
Checked & the water valve responds to vacuum . AT full hot , zero vacuum . Full cold , full vacuum .
God bless
Wyr
