Roady climate control diag question - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 05-13-2015, 10:28 AM Thread Starter
Does anyone know if the roady climate control installed into a 96 caprice displays diagnostic info such as ABS codes?
LTCaprice is offline
post #2 of 3 (permalink) Old 03-02-2016, 05:31 AM
Send a message via AIM to Booth9C1SS
It can display engine (pcm) codes, self diagnostic codes and values, I'm not sure about abs codes.
When I had the swap in my 9c1, I had Brian herter (pcmforless) use the Buick base programming, then add his touch. This add data streaming so the climate control can read it. I don't think the chevy base programming allows for that.
Steve
Booth9C1SS is offline
post #3 of 3 (permalink) Old 03-04-2016, 09:11 PM
Moderator
Goldmaster's Avatar
I know this doesn't answer your question, but I do know at least for the 96 Roadmasters, it will NOT display DTC (engine) codes since it is obd 2. The 94/95s would though since they were OBD 1.
Goldmaster is offline
